MIDI keyboard
Hi
I am trying to create an MIDi keyboard in labview software. i had looked in to some examples mention below. is it neccesary to create separate VI's for NOTe -on ad NOte -Off .  I didnt got logic behind this midi keyboard. could please help me in some way to understand the logis of midi keyboard.
(4,080 Views)
Hi
The example uses event structure to monitor when to play a note. Depending on the sound type selected, when a user press down any key on the keyboard, the "Keydown" event is executed. Within this event structure, the corresponding key code is passed to the "Scan Code 2 MIDI" subVI. This subVI scans for any code that matches the letters (A S D F G H J K L) and generates a MIDI note. The MIDI note is bundled along with other parameters in the "Note On" subVI to form the MIDI data that is then passed to a Windows MCI API dll (winmm.dll) to generate the sound. Likewise when the key is released, the "Key Up" event calls the "MIDI off" subVI that turns off the sound.
Tunde
(4,071 Views)
