Melexis LIN Master and LabView
Dear Alex,
It has been several years since I have interacted with the Lin Master. At the moment I do not have hardware available. I only remember that I have created a VI which presented an interface like the one in the attached image. On the left side you will see that this VI checked for a connection with the Lin Master. Please look at the attached VI. I believe this did the job for me. I am sorry I cannot help further. I have no means to test this.
Good Luck.
Message 11 of 15
(2,048 Views)
Thank you, for answering. The code you attached is the same I have, my problem is that I can Run the MPT App and connect to the melexis, but when I try to do the same from Labview, I can't get anything from the ActiveX functions(Only the default Values), I don't know why.(That mean that the Active X package is installed because I can select the functions in the property nodes, but when some value have to be read or Write I get an error)
Any idea, how to solve this?
Message 12 of 15
(2,035 Views)
Solved:
I received a MLX_Development_Tools_2.3.0("Melexis Development Tools incl. GCC 2.x") with the installer of all the PSF functions, and now it's working perfectly.(The problem was related to the Melexis LIN PSF V1.52.01).
Message 13 of 15
(2,032 Views)
Great, good to know what caused this issue. Best of luck!
Message 14 of 15
(2,029 Views)
you may need the 32bit Labview.
Message 15 of 15
(1,323 Views)
