02-04-2019 04:36 AM
Dear Alex,
It has been several years since I have interacted with the Lin Master. At the moment I do not have hardware available. I only remember that I have created a VI which presented an interface like the one in the attached image. On the left side you will see that this VI checked for a connection with the Lin Master. Please look at the attached VI. I believe this did the job for me. I am sorry I cannot help further. I have no means to test this.
Good Luck.
 AlexRg
			AlexRg
			02-05-2019 05:59 AM
Thank you, for answering. The code you attached is the same I have, my problem is that I can Run the MPT App and connect to the melexis, but when I try to do the same from Labview, I can't get anything from the ActiveX functions(Only the default Values), I don't know why.(That mean that the Active X package is installed because I can select the functions in the property nodes, but when some value have to be read or Write I get an error)
Any idea, how to solve this?
 AlexRg
			AlexRg
			02-05-2019 08:46 AM
Solved:
I received a MLX_Development_Tools_2.3.0("Melexis Development Tools incl. GCC 2.x") with the installer of all the PSF functions, and now it's working perfectly.(The problem was related to the Melexis LIN PSF V1.52.01).
02-05-2019 08:53 AM
Great, good to know what caused this issue. Best of luck!
 aritajiushimei
			aritajiushimei
			06-01-2022 10:24 AM
you may need the 32bit Labview.
