NI 9862 CAN
Hey,
I have tried it and it doesn’t work. I have installed NI-XNET 1.7 with CAN compatibility and have the NI PCI-8512 in MAX. I have selected CAN0 from VI settings and got this error massage
Karenh
Message 21 of 44
(5,391 Views)
You need external bus power for the 9862 module.
Connect your 9862 module to a NI CAN Breakout Box.
https://www.ni.com/en-us/support/model.can-breakout-box.html
Message 22 of 44
(5,386 Views)
Well I will try it tomorrow but I think i will have same problem. Anyway about that CAN Breakout Box don't have it right now. But we have that module in chassis so it can be connected to pc/notebook. So how  can we connect it to that CAN Breakout Box and to pc/notebook?
Message 23 of 44
(5,379 Views)
Connect the Breakout Box with the 9862 module. And connect the Breakout Box with the OBD connector of your CAR.
You can switch on/off the Bus termination at the Breakout Box. Related if you use terminated or non terminated CAN cables.
Message 24 of 44
(5,352 Views)
Ok I see now how it works.
Message 25 of 44
(5,344 Views)
Karenh how did you modifie those VIs?  I keep having this error. Could you please pack and post here your example? Thank you very much.
Message 26 of 44
(5,332 Views)
Hello, please find attached, and please let me know if they are OK
Karenh
Message 27 of 44
(5,326 Views)
I have Labview 2011 could you save it for my version please? I can't open it in my current version. (File->Save for previous version)
Thank you and sorry for trouble
Message 28 of 44
(5,322 Views)
We have a new version of the OBDII Monitor Demo. The demo is working with NI-CAN or NI-XNET.
https://forums.ni.com/t5/Example-Code/OBD-II-CAN-Car-Monitor-Demo/ta-p/3996162
Message 29 of 44
(5,278 Views)
Thank you. Maybe now we won't need external power source. 🙂
Message 30 of 44
(5,273 Views)
