NI-CAN error 0xbff620ad
I'm currently working on a soft realtime "feedforward" application in which a NI-CAN USB interface is used as a CAN frames sniffer. The idea is to read the CAN frames as fast as possible (~50Hz call to ncReadMulti) in order to apply a correction (on some power supplies) which value is computed using the motor-encoders data encapsulated into the CAN frames.  This application works very well in terms of performances but I get a the NI-CAN error 0xBFF620AD something like 10 times per hour. I switched from NI-CAN 2.5.1 to 2.6.3 but it didn't solve the problem.
For the moment, I simply try to recover by resetting/restarting the CAN interface. This action usually takes about 12ms to complete - which is "acceptable" as a temporary workaround. However, I really would like to fix the problem.  So my question is: what is the best NI-CAN driver configuration for such a "listen only" CAN application?
Here is my current configuration:
NCTYPE_ATTRID can_attribute_names[NUM_CAN_ATTRS];
NCTYPE_UINT32 can_attribute_values[NUM_CAN_ATTRS];
//- set baudrate -----------------------------------------
can_attribute_names[0] = NC_ATTR_BAUD_RATE;
can_attribute_values[0] = 500000;
//- start option -----------------------------------------
can_attribute_names[1] = NC_ATTR_START_ON_OPEN;
can_attribute_values[1] = NC_FALSE;
//- length of the incoming CAN frames Q -----------------
can_attribute_names[2] = NC_ATTR_READ_Q_LEN;
can_attribute_values[2] = 0;
//- no writting ------------------------------------------
can_attribute_names[3] = NC_ATTR_WRITE_Q_LEN;
can_attribute_values[3] = 0;
can_attribute_names[4] = NC_ATTR_CAN_COMP_STD;
can_attribute_values[4] = 0;
can_attribute_names[5] = NC_ATTR_CAN_MASK_STD;
can_attribute_values[5] = NC_CAN_MASK_STD_DONTCARE;
can_attribute_names[6] = NC_ATTR_CAN_COMP_XTD;
can_attribute_values[6] = 0;
can_attribute_names[7] = NC_ATTR_CAN_MASK_XTD;
can_attribute_values[7] = NC_CAN_MASK_XTD_DONTCARE;
//- listen only (no write) -------------------------------
can_attribute_names[8] = NC_ATTR_LISTEN_ONLY;
can_attribute_values[8] = NC_TRUE;
I tried to play with the <NC_ATTR_READ_Q_LEN> attribute but it doesn't seem to have any influence on my problem.
Thanks for you help.
NL
(6,798 Views)
Hi NL,
We would to help troubleshoot the error that you are seeing.  Would it be possible to give a bit more information on what function or VI throws the error and also what the error text is?
Cheers,
Kelly R.
(6,766 Views)
Accepted by nl-soleil
I finally found a solution (or at least a stable workaround).
I used to call <ncWaitForState> in order to avoid calling <ncReadMulti> while the input buffer is empty. Removing the call to <ncWaitForState> seems to fix the <0xBFF620AD> error problem. I did modification last friday and everything works smoothly (so far) on the ten of NI-CAN based systems running 7/7 - 24/24 in our accelerator control system.
NL
(6,745 Views)
