‎01-08-2014
02:21 PM
- last edited on
‎06-23-2025
01:27 PM
by
Content Cleaner
I am communicating with the On Board Diagnostics (through the can_h, can_l on the OBD connector) on an Audi A1, with a labview vi based on this example. I use a NI9862 with Xnet.
Now, I would like to log the data as quickly as possible. When I use tdms write, I get about 10 frames per second. Using the NI Bus Monitor (in MAX), I can monitor my vag-com VCDS communicating with the ECU. The bus monitor statistics show about 16 frames/sec. And when I log using the VCDS, I only get about 6-7 frames/sec. Are these normal rates for the diagnose lines in cars?
I wonder what the Bus Monitor statistics frames/s rates would be when monitoring the communication between the labview VI and the ECU. Too bad I need a second ni9862 for that, which I dont have. Actually I wonder what the statistics would show for different diagnose scan tools. I will test that out tomorrow!
grtz
‎01-09-2014 03:41 AM
if you run the NI BusMonitor in the subordinate mode (same port as your LabVIEW VI) you should be able to log the CAN frames.
Hope this helps.
‎01-09-2014 03:50 AM
What do you mean by subordinate mode? You mean in Measurements and Automatisation eXplorer? I wouldnt be able to log the CAN-frames send and received by the labview VI?
This link clearly says "A CAN application cannot use a streaming session on the same port as the bus monitor. This is because the bus monitor already uses a streaming session and that type of session can only be opened once on a port"
As for the logging, I should specify that I'm interested in logging the data values only, not the whole CAN frames..
‎01-09-2014 07:16 AM
From the bus monitor go to Settings >> Interface and Database Settings and change the "Run Mode" from "Normal" to "Subordinate". This allows the bus monitor to connect to the bus but not interefere with the start/stop behavior of your application.
‎01-09-2014 07:57 AM
when you check the VI
obd_ii_monitor_demo\obdii_monitor_demo\Top-Level Source\OBD Get Parameters.vi
you notice that in facht 9 OBD values are read from the ECU. Each OBD Read initiates a handshake which has performance limitations as well, the ECU may also take time to answer the OBD requests, TDMS logging takes some time (the Express VI may has some overhead) so the 10Hz log rate sounds reasonable to me.
