how to import example.ncd in MAX
I am using PCI CAN series 2 ....i want run examples presently ...I am facing problem in importing the example.ncd in MAX please tell me how to do that....................
(5,544 Views)
First of all, make sure that you have installed CAN.  It is a separate step in the installation.  Once you have CAN installed, go to MAX.  In MAX, select Data Neighborhood -> CAN Channels.  On CAN Channels, right click and select Load Channel Configuration.  Here is where you load in your ndc file.
Hope that this helps,
Bob Young
(5,538 Views)
Thanks Bob.....
But i am stil facing the problem ...beacause when i right click the CAN channel (CAN0 or CAN1) it shows only two options in menu i.e. Bus Monitor and properties...... so how can i import now example.ncd?
Amit upadhyay
(5,531 Views)
You are in the wrong place. Don't go to Devices and Interfaces. Go to Data Neighborhood.
(5,528 Views)
Thanks guru..............
My problem has been solved ..........actually i had i talk with NI AE yesterday he told me the same thing as you suggested...
thanks again for reply
Amit Upadhyay
(5,517 Views)
Glad to hear the problem is solved. That is always the most important part. Have a great day!
(5,513 Views)
