This widget could not be displayed.
missing external function ni.can
Hi guys,
i built an exe and when i tried to load it to my second PC i got the error below.
I have to mention that when i run the exe in my PC where i build the vi it works properly.  Also i have build also another VI with analogue data acquisition that runs perfect in both PCs.
Looking forward to hearing from you
Elias
(6,670 Views)
(6,657 Views)
error attached
(6,652 Views)
I think you are missing the CAN driver. You will probably need to install the CAN driver seperately on the second machine or include the CAN driver installer in the executable installer.
Also, I cannot see the links/images in your first two posts, so I am kind of guessing.
Good Luck,
Bob
(6,618 Views)
