using labview, I configure the networks (CAN0 and CAN1) as startOnOpen=false, comparators=xCFFFFFFF, masks=0, writeque=1, readque=0, baud=500000.
I then configure a number of objects (16 for CAN1, 32 for CAN0) for periodic Tx (up to 4 at 12ms, the rest at 100ms), data length=8, writeque=1, TxByResponse=false.  After each object config, I open the object and cWrite the default data.
Next, I open a netObject for CAN0 and CAN1.  I pass these handles as an array into a do-loop (at 250ms) w/ncAction sitting in a for-loop.  Based on a switch, I set ncAction to Start or Stop the network interface.
This works the first time thru.  When I trigger the start, the objects come blasting out (as seen on wraps into a second CAN card and
 using the ni-can monitor).  Shutting off the network works as well.  When I try to restart the network, I get sparodic results.  Sometimes, I can get a few messages out on one interface, most times I get nothing.  If I stop the application (which closes all objects) and restart, it works as stated above.
I'm using ni-can 1.6 and labview 6.0.2  If interested, I can supply source.
Thanks.
