‎04-25-2013 12:09 AM
I am trying to install the NI CAN 2.7.4 software to a cRIO through MAX. I have verified that I have the can module and rio drivers installed. I have CAN 2.7.4 installed on the computer but when I go to MAX to install on the target it won't show up. Does anyone have any experience with this? Can I even use the NI CAN 2.7.4 with the cRIO? I keep reading conflicting information. I have a NI 9853 attached to it if that makes a difference.
Thanks.
Solved! Go to Solution.
‎04-25-2013 12:26 AM
‎04-25-2013 12:32 AM
I'm simply trying to use some of the vis that come with the NI can driver. When I try to use them I get an error say "Failed to load shared library nican.*:nctGetNamesLength:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target." I read that to fix this I need to have NI CAN on the target but it wont show up as a software I can install into it.
‎04-25-2013 12:34 AM
‎04-25-2013 12:37 AM
Not even as a real time vi? I read it can't be used with FPGA but RT is possible.
‎04-25-2013 12:40 AM
