single wire wiring for GM LAN
Can I just connect a PXI-8513/XS to a GM LAN using the pin 3 to GND, pin 9 to 12Vdc and pin 7 CAN_H to the GM LAN?
is it required to connect the pin 5 COM to GND?. I'm using a non terminated cable to conect my interface to my device
(7,713 Views)
Accepted by rgomez7408
It's not necessary to connect pin 5 as this pin correspond to an optional Shield. Here is the CAN manual where you can verify the information (Single Wire CAN)
http://www.ni.com/pdf/manuals/370289j.pdf
Depending on the baud rate that you are using, you could have problems if not using a terminated cable (low-speed may work but at higher speeds you may encounter some problems).
I hope this is useful!
Regards
José Alberto G.
ELP Support Engineer
www.ni.com/soporte
(7,638 Views)
