BreakPoint
Funny threads
LOL!!  Out of context, my sentence makes no sense.  LOL 😄
As I recall, the OP wanted to open or run a VI (not compiled) without having LabVIEW installed.
I may have been corrected that it is possible.  I have not tried it yet.  I am building a new PC and will create virtual machines running windows.  I will have to try it 🙂
Message 361 of 537
(11,496 Views)
Ofcourse you have to keep diagram and code in the same file, no split code and panels. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 362 of 537
(11,460 Views)
Somebody is responding to a coop position from 13 years ago!
http://forums.ni.com/t5/LabVIEW/Undergrad-Students-Co-Op-position-available-using-LabVIEW/m-p/236127...
Message 363 of 537
(11,409 Views)
I post a problem on the forum.
Application engineer posts an example which does not illustrate the problem (and doesn't really even come close).
A week alter Same application engineer posts on the problems with HIS code and thinks the problem is solved.
Facepalming ensues.
HERE.
Shane
Message 364 of 537
(11,358 Views)
Facepalming ensues.
HERE.
Shane
Ugh, then I post my code which demonstrates the issue and he replies asking me to post code......
It's not April 1st yet is it?
Shane
Message 365 of 537
(11,353 Views)
Yep, that is gettting a little rediculous.
Here is what you did wrong in the example I gave you.
Oh, and it is apparent you have never touched FPGA.
*rolls eyes*  I'd be really tempted to request a new AE.
Message 366 of 537
(11,334 Views)
Facepalming ensues.
HERE.
Shane
Shane
HA! I just came to post your thread here, but I saw you already beat me to it. Look, I even have the link copied already(http://forums.ni.com/t5/LabVIEW/polymorphic-VI-on-FPGA/td-p/2357234)
Message 367 of 537
(11,280 Views)
hahahaha! Lots of abuse, and probably deserved Smiley Very Happy
http://forums.ni.com/t5/LabVIEW/how-to-get-a-decimal-number-of-length-more-than-1-byte-from/td-p/237...
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 368 of 537
(11,207 Views)
When somebody tries to make the front panel smaller and "delete the extra blank space since I do not need it" is the most serious stumling block, we are in trouble!!! :o:D
(That seems similar to trying to delete the unused HD space or kill that pesky "idle process" that seems to be using nearly 100% of the CPU at all times :D)
Message 369 of 537
(11,174 Views)
So, of your car won't start, sending a picture of the speedometer stuck at zero probably won't be very helpful to your mechanic in diagnosing the problem.
,,, so why would it seem like a good idea here to illustrate a problematic LabVIEW program with screenshots of the task manager and the system propert...? No word about the program itself!
Message 370 of 537
(11,104 Views)
