BreakPoint
I used a stacked sequence today. So sue me.
Yes, any sequence local can spoil a perfectly good sequence. 🙂
(In 17 years of LabVIEW programming, I've only found a single instance where a stacked sequence was useful, and it did not involve any locals.)
Message 11 of 18
(5,520 Views)
@PaulG. wrote:
Smiley Tongue
Looks similar to some code i inherited. I made a small help-vi that extracts the Channel clusters and build them into an array, that way it's easy to look or index individual ones. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 18
(5,508 Views)
I'm trying to remember the last time I used a stacked sequence before this instance. It was in my noob days (>10 yrs ago). When I was whipping this up the stacked sequence seemed like a useful choice. After I wrote it I felt "dirty". Smiley Wink
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 13 of 18
(5,499 Views)
I've found quite a few instances of stacked sequences which were useful.  Mind you, they were all in order to show people why you shouldn't use them so yeah, they're not a common visitor to my block diagrams.
Message 14 of 18
(5,476 Views)
LOL!!
Message 15 of 18
(5,426 Views)
WHY???
If not a dirty patch to add some channels where only one was designed 😉
EDIT:
so a dirty patch to get 3 Ch on a dirty patch to get 2Ch ? 😉    and never mind, for the cluster we have a type def everywhere ... (I hope!)
Greetings from Germany
Henrik
LV since v3.1
Message 16 of 18
(5,420 Views)
This stacked sequence was used mostly for real estate concerns on my block diagram. However, the functionality has expanded to where not only will the stacked sequence go away but the all of the code it contains will go into a sub-vi. "Problem" solved.
Sorry for causing a disturbance in the Force. Smiley Sad
But I would do it again. Smiley Happy
PaulG.
Message 17 of 18
(5,407 Views)
LOL!!   The Force needs to be disturbed...  otherwise it becomes static (and useless)
Message 18 of 18
(5,386 Views)
