BreakPoint
Monthly Bugs, August 2012
Continued from the July 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
This will be a very exciting month!
Today (Aug 1.) is Swiss National Day and next week is of course NI Week!!! See you all in Austin!
Message 1 of 10
(12,991 Views)
Configuring the 5922 with the 5900 preamp and setting the input range according to the preamp and (after committing) reading the choosen input range property results in a wrong information.
Here 160V instead of 40V 🙂
(while the dataoutput is correct)
Posting here
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 10
(12,959 Views)
The behaviour has changed from the earlier versions of LabVIEW. Most probably unintentionally.
Posted here
Message 3 of 10
(12,920 Views)
Error 1 is generated when trying to register an array of controls.  No CAR# assigned yet.
2012 Dynamic Event Registration Array of Controls
Message 4 of 10
(12,888 Views)
GUI bug while using event structure. Details available in LabVIEW GUI Bug? thread
Message 5 of 10
(12,840 Views)
The refnum of a typedef'd control does not match the refnums for any control on the panel for LabVIEW 2011 and 2012
CAR# 367463
Message 6 of 10
(12,798 Views)
You'd have to pay me to go to Austin in August (or any other month for that matter).
This being said, here is an annoying bug that need acknowledgement by NI:
Plot 0 visibility in a Graph cannot be unchecked (LV 2012f1)
Message 7 of 10
(12,736 Views)
X...that one was already reported. See above.
Cheers,
Cerati
Message 8 of 10
(12,726 Views)
Looks like LV2012 has a bug in their compund arithmetic when using units and trying to do some multiplication:
http://forums.ni.com/t5/LabVIEW/Labview-2012-compound-arithmetic-function-breaks-VI-using-units/td-p...
Message 9 of 10
(12,709 Views)
August is over. The September 2012 bug thread can be found here.
Thread closed!
Message 10 of 10
(12,654 Views)
