BreakPoint
Monthly Bugs, October 2012
Continued from the September 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 16
(15,979 Views)
Performance hit on LV2012 when using dynamic dispatch VI's, thread found here. CAR #372784
Br,
/Roger
Message 2 of 16
(15,967 Views)
Some terminals of the in place element structure (e.g. variant to/from element border node) have missing or incorrect tip strips when wiring. (details)
Message 3 of 16
(15,924 Views)
Weird behaviour of FPGA Interface configuration in a typedef'd FPGA Reference control. Thread here.
Br,
/Roger
Message 4 of 16
(15,883 Views)
Labview Crash with Dynamic Event Registration and Event Structure. Thread here.
Br,
/Roger
Message 5 of 16
(15,874 Views)
(LabVIEW 2012f1)
Crash reports have a file modification date that is about 1 month into the future. (details)
Message 6 of 16
(15,851 Views)
Clearing the compiled object cache causes internal warnings and the error reporter to run on 64 bit Windows 7.
On a 32 bit Windows 7 the VI will be broken with an out of memory condition. Thread here.
Br,
/Roger
Message 7 of 16
(15,807 Views)
Several compiler error popups, and a broken arrow fixed by forcing a recompilation in LV2011 SP1 LVOOP code with an overridden method. Thread here.
Br,
/Roger
Message 8 of 16
(15,780 Views)
The LabVIEW Application Builder has some serious issues with the code complexity. Perhaps O(n^2) or worse. Building a medium size application takes more than 6h on a fairly modern Intel Core i7 machine. There are also some bogus errors after the building completes. Thread here.
Br,
/Roger
Message 9 of 16
(15,748 Views)
Timed structures in parallelised for loops unavoidably cause duplicate structure name error -808, here
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 10 of 16
(15,697 Views)
