11-09-2012 11:34 AM - edited 11-09-2012 11:35 AM
@JÞB wrote:
Some are even easier. 😄
Note: the timestamp to time record can actually take a dbl but the number to timestamp function is just soooooo pretty
That would wrap the hours above 24! A number of 123456789 would yield 13 hours in your code, probably "slightly" too low. 😄
11-09-2012 11:48 AM
Easilly scaleable!
11-09-2012 11:55 AM - edited 11-09-2012 11:55 AM
@JÞB wrote:
Easilly scaleable!
Interesting slip ....
Now it gives 8005 hours instead of the expected 34293 when starting with 123456789.
O course you could now also handle the years, but I thought the original idea was based on "easier". 😄
11-09-2012 11:55 AM
@JÞB wrote:
Easilly scaleable!
And now you need to include the number of years! And we are quickly getting more complicated than the simple quotient and remainder. But the idea is a good one, Jeff.
11-09-2012 12:00 PM - edited 11-09-2012 12:07 PM
No, it will not work in general. For example if you do the "day of year correction" and use an input of 123, the result would be 8776:2:3. Way off!
11-09-2012 12:13 PM - edited 11-09-2012 12:19 PM
Drat Snippett tool
Fine- do it the other way then
11-09-2012 12:42 PM
I am happy it is getting "easier" by the minute. Soon we'll be at my original suggestion from yesterday. :o:D
11-09-2012 12:47 PM
That gets funnier by the second now that I looked at the source thread!
11-11-2012 01:07 AM - edited 11-11-2012 01:11 AM
Just note that no one else has your subVI, thus making the snippet less practical for others. 😉
Also, for those who don't know, this wouldn't be relevant in this case, but To DBL can be used to convert a timestamp to the number of seconds since 1904.
11-11-2012 09:32 AM
