BreakPoint
Rube Goldberg Code
Assuming you start with the correct four input bytes, another option would be a word swap. Same result. 😉
Message 1801 of 2,635
(11,913 Views)
Sorry to bring this back to an "old" topic, but I found a nice selection of code. It was actually the shift register button was attached to. I had to split it into 2 halves because it was long.
The biggest offender is the case structure with a constant false, and the false case only passes the cluster and error wires right across. The only reason I could think of is debugging, and then forgot/didn't care to clean up.
The person who wrote this code really loves case structures and flat sequences, and they also don't trust error clusters.
Message 1802 of 2,635
(11,865 Views)
Instead of using a boolean to determine which case of a case structure to use, Let's use the words "start" and "stop" in strings, but check the length of the string and determine whether it is 4 or 5 characters long.  Because you know that "plate" should be just as valid to start something, and "lion" would be just as valid to stop it.Smiley Surprised
Seen here  http://forums.ni.com/t5/LabVIEW/Internal-error/m-p/3586987#M1004531
Message 1803 of 2,635
(11,852 Views)
Personally I prefer to use "Init" and "Cease" in that sort of code!Smiley Very Happy
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 1804 of 2,635
(11,799 Views)
Or:
"DoIt"
"DoNot"
CLA
Message 1805 of 2,635
(11,794 Views)
It starts to be interesting when you add "exit" and "error" ... but with the current code you can send "f*ck" and "S4T4N". 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1806 of 2,635
(11,741 Views)
/Y
So how would the documentation read for that case structure?
If it was S4t4n Or  is S4t4n and  is not f*ck then it is S4t4n
Ben
Message 1807 of 2,635
(11,710 Views)
I like the syntax "If it is ABORT or was ABORT and it is not GOOD then, START."Smiley Surprised
Message 1808 of 2,635
(11,698 Views)
Every time I hear code in sentence form, this (missile guidance description) starts playing in my head.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 1809 of 2,635
(11,653 Views)
But don't start with Phenomenology 😄
The Dark Star bomb (most important part 11:28)
Greetings from Germany
Henrik
LV since v3.1
Message 1810 of 2,635
(11,639 Views)
