BreakPoint
Rube Goldberg Code
BowenM wrote:
(Disclaimer:  this was most likely written by a grad student who had never seen LV before and was just told to make it work)
Maybe (s)he was told he got paid until the job was done? In fact that's very smart.
Message 1861 of 2,635
(12,223 Views)
@altenbach wrote:
@BowenM wrote:
... and was just told to make it work)
And I guess it actually "worked" 😄
I wouldn't guess it did. Somehow I think that THAT is not the right way to calculate %charge unless the ??? units are really odd.
Message 1862 of 2,635
(12,213 Views)
The "???" array is the maximum currents for each magnet, and is used when sending the command to the power supply.  This part I'm actually surprised works because it is a topnotch local variable induced race condition.
Edit:  I lied... it isn't a race condition just oddly coded.
Message 1863 of 2,635
(12,200 Views)
Silly me! I simply expected a physics grad student to use Q for electric charge (SI Ampere Seconds) Placing ??? as Seconds.  %Ampere Seconds being rather odd
Message 1864 of 2,635
(12,174 Views)
(seen here)
What kind of high-school teacher would teach the students to program like that??? 😮
Message 1865 of 2,635
(12,046 Views)
A nickel is also 40cents which is a solid exchange.
Message 1866 of 2,635
(12,041 Views)
Yes, a candy bar for two nickels sounds like a pretty good deal. 😄
Message 1867 of 2,635
(12,037 Views)
But that loop will probably cause the processor to run a little hot, so don't get anything chocolate.
Message 1868 of 2,635
(12,024 Views)
Not if you buy %0.60 chips for 1 buck and only get a nickel back
Message 1869 of 2,635
(12,017 Views)
@altenbach wrote:
(seen here)
Didn't want to spoil your fun on the other thread but "$%0.2f" and "%d¢" (%dAlt+0162) would blow the teachers mind!  but, at least the array constants would make sense cents
(The urge to include the pun was irresistible, Oh well!  )
Message 1870 of 2,635
(12,002 Views)
