BreakPoint
Rube Goldberg Code
@bsvare wrote:
I've sadly also met my fair share of horrible drivers. A lot of what I encounter are DLL wrapped VIs. Lately, though, I'd be happy to see that vs some of what I have been seeing lately.
For example, the latest driver I got has this "Init" function:
It requires passing in references to controls I don't use, need to know internal of which port is RS232 vs RS485, and Comport and MacID per connection.  (Among other Rubes).
In fact, the "driver" is just 4 VIs, Init, Status, State, and Main (Demo VI)
At least the error chain is unbroken!  You should have seen what this looked like before.
And it used "VISA.User Data"  That's a no-no  (Waves finger /\/\//\/)
User Data clears before the vi calling it goes idle (Not saved by VISA as part of the session that you may not need to explicitly open)
Message 1941 of 2,635
(11,331 Views)
(seen here)
I will spare you from looking at the entire diagram, so here is just a very small section 😮
Message 1942 of 2,635
(11,327 Views)
Oh, that sad and lonely Wait function at the left bottom... 🙂
Message 1943 of 2,635
(11,314 Views)
@crossrulz wrote:
But the ones that really irk me are the ones that have DLLs to do simple SCPI commands.  Seriously?  Couldn't just use the normal VISA functions?  Those I am quick to completely throw away and write my own.
Absolutely! We use TESCOM Pressure Controllers here. TESCOM have a DLL. They paid someone to wrap the DLL in LabVIEW VIs and provide that as a LabVIEW driver. I got a hold of the comms protocol to the TESCOM device and wrote a native LabVIEW interface. Now that mine is written in pure LabVIEW, it's portable to cRIO (Linux) etc. Much better Smiley Very Happy
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 1944 of 2,635
(11,266 Views)
Let's really complicate the creation of an array with what is really a 1-D array at the end of the day.
Seen here.
Capture
Message 1945 of 2,635
(11,109 Views)
Hmmm... It's exemplary for the rest of the thread (and code):
Message 1946 of 2,635
(11,057 Views)
1. Write LabVIEW Code
2. Find less than 0 devices
3. Get infinite devices!
4. Profit $$$
Message 1947 of 2,635
(11,036 Views)
4. Profit $$$
The Ferengi Rules Of Acquisition # 9   "Opportunity plus instinct equals profit."
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 1948 of 2,635
(11,003 Views)
4. Profit $$$
In his defense...
Spoiler
I regret it already (FRA 285)...
Only case 1 and 2 did something, 0 was default... (That extra info makes the code less wrong, but 100% redundant!)
Message 1949 of 2,635
(10,997 Views)
Here's one way to determine if the current code is run as executable (seen here).
Also that uninitialized shift register would be problematic if run more than once during a session.
I am pretty sure there is a better way!
Message 1950 of 2,635
(10,961 Views)
