BreakPoint
Rube Goldberg Code
Maybe there needs to be another thread called "code only a mother...original developer... could love...understand"   Joe's post 268 could certainly fit into that category even if it's not meeting the Rube Goldberg criteria.Smiley Happy
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 271 of 2,635
(13,570 Views)
Thanks Steve..
Today's been one of those days... A BAD-POST day for me..   sigh 😞
3 months no coffee..  WHat a switch from the daily dose of Espresso...   😮
Message 272 of 2,635
(13,537 Views)
3 months no coffee, no wonder you lost half of your eye sight. Smiley Very Happy
The mentioned code isn't bad, the programmer is just relucting in removing long executing code in a event structure.
Ton
My LabVIEW Ideas
Message 273 of 2,635
(13,501 Views)
Misquoting Salieri: "Too many loops!"
All better, same result:
Message 274 of 2,635
(13,399 Views)
Whew, that's bad!
(1) Here's a small section of the diagram, see the navigation window for an overview.
Some other nuggets found:
(2) Let's index out of an empty array to get an empty scalar perhaps???? What!!!????
(3) Use some backwards wires, unneeded locals (Race conditions!: There is no wat to guarantee that the local is read before the terminal is written).
Message Edited by altenbach on 06-12-2008 10:56 PM
Message 275 of 2,635
(13,338 Views)
Continued from previous post:
Use "delete from array" to get an array slice as 2D array, take a 2D subset, transpose, and get a slice. .... 😮
Message Edited by altenbach on 06-12-2008 10:59 PM
Message 276 of 2,635
(13,389 Views)
We need to typecast a string to a U32 array. The hard part seems to get "something" for the type input....
Simple! Just convert the U32 array output to a digital waveform, then, via a feedback node convert the digital waveform back to a U32 array and use that for the type input of typecast. 😄
Message Edited by altenbach on 06-19-2008 09:14 AM
Message 277 of 2,635
(13,276 Views)
A simper way to convert a string delimited by commas into an array..
For some reason, it appears that a 2D array was desired???  Hummm...  not sure...
Message Edited by JoeLabView on 06-19-2008 09:44 PM
Message 278 of 2,635
(13,245 Views)
Sometimes even the experienced among us somehow get stuck into generating Rube Goldberg code in a momentary lapse of thinking:
from http://forums.ni.com/ni/board/message?board.id=170&thread.id=333631
Message 279 of 2,635
(13,192 Views)
LOL!  Good catch smercurio.
If interested, here is the final example for the R-G code above..  The one with the While Loop...
Message 280 of 2,635
(13,187 Views)
