BreakPoint
Rube Goldberg Code
@JÞB wrote:
Some are even easier.   😄
Note: the timestamp to time record can actually take a dbl but the number to timestamp function is just soooooo pretty
That would wrap the hours above 24! A number of 123456789 would yield 13 hours in your code, probably "slightly" too low. 😄
Message 1191 of 2,635
(11,266 Views)
Easilly scaleable!
Message 1192 of 2,635
(11,258 Views)
@JÞB wrote:
Easilly scaleable!
Interesting slip  ....
Now it gives 8005 hours instead of the expected 34293 when starting with 123456789.
O course you could now also handle the years, but I thought the original idea was based on "easier". 😄
Message 1193 of 2,635
(11,252 Views)
@JÞB wrote:
Easilly scaleable!
And now you need to include the number of years!  And we are quickly getting more complicated than the simple quotient and remainder.  But the idea is a good one, Jeff.
Message 1194 of 2,635
(11,251 Views)
No, it will not work in general. For example if you do the "day of year correction" and use an input of 123, the result would be 8776:2:3. Way off!
Message 1195 of 2,635
(11,246 Views)
Drat Snippett tool
Fine- do it the other way then
Message 1196 of 2,635
(11,236 Views)
I am happy it is getting "easier" by the minute. Soon we'll be at my original suggestion from yesterday. :o:D
Message 1197 of 2,635
(11,227 Views)
That gets funnier by the second now that I looked at the source thread!
Message 1198 of 2,635
(11,220 Views)
Just note that no one else has your subVI, thus making the snippet less practical for others. 😉
Also, for those who don't know, this wouldn't be relevant in this case, but To DBL can be used to convert a timestamp to the number of seconds since 1904.
___________________
Try to take over the world!
Message 1199 of 2,635
(11,184 Views)
Yair, that is a Time to Time of Day.vi. One of the three vi I famously proposed for addition to the timing palate. It returns seconds since latest midnight. I have found it fairly useful. Can't link from mobile so follow the trail from my profile page starting with my most kudosed post.
Message 1200 of 2,635
(11,171 Views)
