BreakPoint
Rube Goldberg Code
Not quite as exciting as the above Rube, but here's an interesting way to get the rows of an array.  I did the block diagram cleanup, so keep in mind it looked worse.  Found here:http://forums.ni.com/t5/LabVIEW/Why-my-program-not-stopping/m-p/2300632#M724468
Message 1261 of 2,635
(11,722 Views)
According to the thread he wants to split the 2D array into 2x 2D arrays, one with the even rows and one with the odd rows. Even your cleaned code simply rattles through the array and displays the last row after a few nanoseconds, nothing else. How useful is that?
Message 1262 of 2,635
(11,693 Views)
Exponentiation, the hard way (or if the exponential function never existed):
(seen here)
Also notice that with the above code the exponentian needs to be done [Dim1xDim2] times with lots of duplicate recalculations, while it would be sufficient to do it [Dim1+Dim2] times. For example, with a 1000x1000 result, the difference would be 1000000 vs 2000, or 500 times less with more efficient code.
Here's what I would probably do. Same result!
Message 1263 of 2,635
(11,623 Views)
I suppose this could go in to the funny threads as well. I do feel for Norbert though!
Here is an interesting rube:
http://forums.ni.com/t5/LabVIEW/Terminating-two-independent-while-loops/m-p/2323086#M728938
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 1264 of 2,635
(11,510 Views)
It's not just AN interesting rube.  It is a TON of rubes. *shaking head*
My favorite is getting a subarray of 1 element and using the type cast to turn the subarray of U8 into a U8.
Message 1265 of 2,635
(11,494 Views)
I especially had to laugh about the quote "The block inside first while loop can't be small."
I understand it when people say they don't want/need it to be small, although I don't agree with them.
Maybe it's some kind of moral belief or esthetic principle ("and then there was free block diagram space!") 🙂
I always find it a challenge when people use words like never, always, can't, ...
(and yes I know I used always in this sentence 🙂 )
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 1266 of 2,635
(11,492 Views)
Rube discussed here
Original post:  OP was trying to apply a linear adjustment (numeric) but had created an array of strings.
someone suggested: for the linear adjustment
People should NOT overconvert!
Message 1267 of 2,635
(11,395 Views)
Homework gone wrong:
part of the solution... (I think)...  😉
Discussed here
Message 1268 of 2,635
(11,295 Views)
Horror!
Found here: http://forums.ni.com/t5/LabVIEW/Running-LED-in-FPGA/m-p/2332192#M730755
Message 1269 of 2,635
(11,162 Views)
Wow, in the lower res view here that looked like a complex timing diagram rather than a block diagram!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 1270 of 2,635
(11,148 Views)
