BreakPoint
Rube Goldberg Code
@.aCe. wrote:
Horror!
Found here: http://forums.ni.com/t5/LabVIEW/Running-LED-in-FPGA/m-p/2332192#M730755
The snippet is a bit misleading, because it turned all local variables into generic property nodes with references. Still, the original VI seems to do all integer calcuations in floating point (DBL!). All terminals disconnected and all using local variables. (e.g. A1 is read from 21 different local varaibles in the first frame)
Message 1271 of 2,635
(11,581 Views)
Looks like a microprocessor schematic from a distance.
Message 1272 of 2,635
(11,550 Views)
It should also make the Local abuse thread..    A candidate to post an idea on how to improve Locals by making them 3D (or something foolish)
Message 1273 of 2,635
(11,523 Views)
View Locals as Icons Smiley Very Happy
Message 1274 of 2,635
(11,512 Views)
ROFL!!
Message 1275 of 2,635
(11,509 Views)
I had already considered posting that Idea exchange thread around the 1st of next month (Apr 1st).  I then thought Oh, C@#p! What if it gets a bazillion kudos?  Could I deal with my forum alias being "Credited" with that new feature?
Locals are not evil- but, they do cause a few problems when miss used!  I recall my Greek authors.  I believe Aesop's tortoise was snorting opiates, The hare might have been dropping 'Ludes.  A classic "Race Condition!"
Message 1276 of 2,635
(11,522 Views)
Seen over here. Although, I made the assumption it was one long, \n delimited string, but I think it was actually separate strings just multiple examples for us to work with. A plain old scan from string works if it is separate strings.
Message 1277 of 2,635
(11,518 Views)
On FPGA you could make a case structure with a constant in 17 cases, or you could use scale by a power of 2. Good thing it wasn't a 64 bit number....
I should add, I guess I could have a constant array and index it, because the "i" is actually an input in the real code, with no for loop.
Message 1278 of 2,635
(11,379 Views)
I'm curious if there's another way to get a 0 as the first element without using the select (and without a build array after the loop). Any takers?
What's the point of your code? Since all inputs are constant, you might as well create a lookup table and use no code at all. (most likely that's what the compiler does anyway ;))
Message 1279 of 2,635
(11,369 Views)
Something like this?
Message 1280 of 2,635
(11,368 Views)
