BreakPoint
Rube Goldberg Code
@Yamaeda wrote:
Nice tweak to mine, haven't thought about Logical shift being able to take arrays. 😄
/Y
Yeah, but won't both be folded to equal constants in real code?
Message 1291 of 2,635
(11,306 Views)
/Y
Well there is no real difference in diagram size, and the compiler might even generate the same code for both versions (not sure). 😄
A benchmark would be interesting... (Yes aboud folding by placing a control on N).
For truly gigantic arrays, the first version can be parallelized while the second version might be abe to take better advantage of SIMD instructions. (?)
Message 1292 of 2,635
(11,295 Views)
@altenbach wrote:
/Y
Not that likely.  Aren't rotations prohibited in SSE?
(Over my head here- but, allways learning!)
Message 1293 of 2,635
(11,285 Views)
 I have no idea, that's why I said "might". (here's a list of instructions, so I guess you are right)... 😉
Message 1294 of 2,635
(11,279 Views)
Hey guys.
As some people here know, I'm not that experienced in LabVIEW.
Some time ago I needed to do a function (subroutine) that had to split a string received from a serial buffer into several substrings. My token is a comma ( , ).
This is used to read sensors information from a certain firmware. As you can see below, I'd have to change the number of substrings (our firmware documentation provides that) in every single application (since this is a minor monitoring system, we use lots of them).
Before...
... and after ...
The thing here is:
I feel really stupid.
There's somehow to improve this new function (and make me feel more stupid)?
By the way, really nice thread. I was browsing the answers in a spare time yesterday, and I could see very good tips and tricks.
Regards
Mondoni
Message 1295 of 2,635
(11,223 Views)
Hi Joao,
what about using SpreadsheetStringToArray with a delimiter of ","?
Message 1296 of 2,635
(11,218 Views)
I don't see what you are pointing, exactly.
Can you please post a snippet? I'd be happy 😄
Regards
Mondoni
Message 1297 of 2,635
(11,218 Views)
Like this.
Message 1298 of 2,635
(11,210 Views)
Hi Joao,
the point is that something little like that will split your string into smaller pieces:
Message 1299 of 2,635
(11,208 Views)
Well, if you want to retain the same functionality (cluster output!) use what I do in the top part.
(your code is at the bottom unchanged. Both give the same result)
Message 1300 of 2,635
(11,204 Views)
