BreakPoint
Rube Goldberg Code
Wonderful.
Thank you guys.
Didn't know this function.
Regards 😄
Mondoni
Message 1301 of 2,635
(10,948 Views)
@crossrulz wrote:
Like this.
Still, A bit R-Gish when you only need:
(Handles optionally ignoring case of the delimiter too)
Message 1302 of 2,635
(10,897 Views)
@JÞB wrote:
@crossrulz wrote:
Like this.
The advanced string functions really need to be promoted to the palette.  And I really need to start using them as well.  Make people freak out by using hidden functions.  And that one there is one I could use all the time.
Message 1303 of 2,635
(10,877 Views)
just a tip
Message 1304 of 2,635
(10,868 Views)
Basically, we have a few boolean arrays and are trying to count how many are true. (Typically a near atomic operation "boolean to to (0,1)" + "add array elements").
Here is a small part of a FOR loop that tries to to about the same in the RG way. 😄
Yes, the actuall code is significantly larger, see for yourself!
(original thread)
Message 1305 of 2,635
(10,832 Views)
Q: Help! I am running out of memory quickly!
A: Aha! Why don't I simply add a delay so it runs out of memory more slowly! Genius!
(paraphrasing from here)
Message 1306 of 2,635
(10,794 Views)
(original thread)
There's a bug in the code...  Can you find it??  THere's a -1 in (at least) one of the False case(s).  Maybe it's not a bug.... maybe it was intentional...  OMG!!  What code!!
Message 1307 of 2,635
(10,673 Views)
@Ray.R wrote:
What code!!
How does it cope with a full block diagram cleanup?
Message 1308 of 2,635
(10,656 Views)
Hi Rhino,
it does work quite ok: a lot of straight wires with kind of hypnotic look...
Does it really need to STOP the VI when the parking lot is too crowded? I can imagine the reaction of possible users 😄
Message 1309 of 2,635
(10,642 Views)
It also stops when it's empty...
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 1310 of 2,635
(10,637 Views)
