BreakPoint
Rube Goldberg Code
The consesus seems to be that if code does not work right, the only solution is to throw even more code at it. 😄
So if a shift register does not work as expected, maybe we can add a few more N=1 FOR loops so we can pipe the data through more shift registers. The idea probably is that asymptotically the code will work perfectly after we repeat that for an infinite number of times. 😄
(seen here)
Message 1371 of 2,635
(11,825 Views)
Changing the color of a scatter plot (seen here) to a single color can be extremely complicated and require sequence frames unbundling and bundling of unchanged elements, making a custom ramp with all the same colors and three property nodes.
Or it could be done with two property nodes and 10% of the code.
Message 1372 of 2,635
(11,798 Views)
Creating a simple 2D image apparently needs 4 FOR loops, many identical diagram constants and a couple of DBL arrays, if all we really need is a final U8 array to convert to a picture. The insert shows basically the same code (the scaling is slightly modified, but that's irrelevant).
Message 1373 of 2,635
(11,723 Views)
Instead of using a boolean to drive a case structure, let's convert the boolean to the string values of "True" and "False" and use the string value to drive a case structure.
Seen here.
(I'd attach the screen shot as a file and embed it, but apparently .pngs are still busted as "The contents of the attachment doesn't match its file type" when I try to upload it.)
Message 1374 of 2,635
(11,610 Views)
Maybe they want a True, False and a "Don't really know" option?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 1375 of 2,635
(11,594 Views)
A particular favorite of mine that I came across last year was this:
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 1376 of 2,635
(11,617 Views)
Having just sat the CLD exam (after years of procrastinating) I can tell you that NI has put together some very nice exam preparation material to help you pass.
CLD Preparation E-Kit
I highly recommend going through it thoroughly... except maybe ignore these bits:
CLD 4 Event Structure Timer Solution.vi
CLD 4 Event Structure Timer Solution.vi rube.png Classic Rube / Wire Equivalent Code
CLD 16 Add process.vi
CLD 16 Add process.vi rube.png Constant Equivalent Code? T=0 F=0
Hmmm, maybe I should wait until I get my results back before I point this out?
There's probably more rube in my 1 exam submission than in all the preparation material.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 1377 of 2,635
(11,518 Views)
That first one has remarkable similarity to my avatar.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 1378 of 2,635
(11,452 Views)
You might have been their inspiration 😉
Kind Regards,
Message 1379 of 2,635
(11,405 Views)
It's a Bool-to-Int on Line Two. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1380 of 2,635
(11,408 Views)
