BreakPoint
Rube Goldberg Code
(Seen here)
So we take a scalar, built it into an array with one element, measure the array size, subtract one, then use that to index into the array.
It is amazing that a plain wire could probably do the same thing! Magic! The true power of LabVIEW.
Message 1381 of 2,635
(11,026 Views)
@altenbach wrote:
(Seen here)
But, is a wire "Scalable"  What if there were more elements wired to the build array?  (Delete from array would be the "Better" solution)  Smiley LOLSmiley LOLSmiley LOL
Message 1382 of 2,635
(11,018 Views)
 Yes, of course! Fully!!!
(...If you enlarge the diagram or move nodes, the lenght of the wire scales automatically to cover the distance between the attachment sites.)
Message 1383 of 2,635
(11,004 Views)
It's obviously a current boosting circuit, where the output is isolated from the input. Very common. Smiley Tongue
Richard
Message 1384 of 2,635
(10,965 Views)
(Seen here)
Of course I would have to see the code before making a final judgement, but this descriptions just makes me cringe.
"... multiple Event Structures under a while loop."
What kind of design pattern is this?? Where is "under"? 😮
Message 1385 of 2,635
(10,923 Views)
@altenbach wrote:
(Seen here)
Prepositions are very language dependant, and in this case i assume Under = Inside. (Under the span/cover of a loop, maybe?) It's just like i never understood why the english are angry WITH people? I'd say it's more natural to be angry AT people. 🙂
It's a great solution if you want to be able to handle several events at once if once takes a long time ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1386 of 2,635
(10,838 Views)
@jcarmody wrote:
Post the VI you're writing and we'll help you learn what you need to write a proper solution (mine is slightly obfuscated).
Ok so we know it was intentionally obfuscated, but now it's time for me to get help from the LabVIEW super-experts.
I was thinking of ways to improve it, and came up with this:
Can anyone give me a way to shrink it down even more?
Message 1387 of 2,635
(10,778 Views)
The students are back! Some admit it, others not so much.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 1388 of 2,635
(10,733 Views)
Well uploading the assignment sheet makes it kinda obvious 😛
Having said that, we should probably expect another round of licence plate recognition posts soon.
Message 1389 of 2,635
(10,703 Views)
Yes, it's the season of Rubes, a time to be jolly. 🙂
/Y
Qestit Systems
Message 1390 of 2,635
(10,588 Views)
