BreakPoint
Rube Goldberg Code
5.1 had the do while true default. and yes I strongly suspect that this is "Legacy" code.  (Note the lack of VISA)
Which brings up an interesting side discussion from yesterday's Developer Days panel.
"I'm going to update some code to LabVIEW 2013,  What should I look out for with my 2009 source?"
The consencus seamed to be "No worries except expect the optomizer to come around and improve performance... but everything..... Re-Review everything!"  get rid of error 42, use Events.  Use IPEs sparingly, are those VITs you are launching? try an ACBR?  if you upgrade your code "Upgrade it!"
Further conversation revealed the "2009 source code" was old enough to get a drivers license!
Message 1471 of 2,635
(11,302 Views)
My very first VIs are that old. I don't know if I should laugh or cry. And yes, I'll vouch that do while true is at least V 5.1.
PaulG.
Retired
Message 1472 of 2,635
(11,277 Views)
A simple task is to parse a 2D array of strings into date/time (first two colums) and data (third column or above) for display on an xy graph.
A recent such case came up here. array Indexing (5x), array size, initializie arrays (2x), shift registers (2x), insert into array (2x), etc. etc.
... or some simple stamp sized code. You pick! 🙂
Message 1473 of 2,635
(11,207 Views)
It's those complex numbers again!
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 1474 of 2,635
(11,133 Views)
Most beautiful Block Diagram which I have ever seen:
Acquired from this thread.
Message 1475 of 2,635
(11,123 Views)
Wow.
Looks like PCB tracking in places! 🙂
CLA
Message 1476 of 2,635
(11,166 Views)
I tried watching it run with highlight execution on. I thought it was going to crash my system. Smiley Surprised
PaulG.
Retired
Message 1477 of 2,635
(11,126 Views)
I like it. it looks good. I only still have no idee what he is trying to do and what is problem is. ( exept to much time )
Learning LabVIEW since January 2013
Message 1478 of 2,635
(11,110 Views)
Is this supposed to run on an FPGA?
So who can translate it into postage stamp sized code e.g. using boolean arrays instead?
Message 1479 of 2,635
(11,065 Views)
Translate it? It's art!  The OCD parts of my brain are mesmerized.
Forget wether or not it works, the block diagram is a thing of beauty.  I think I will print it out and frame it.
I suppose it would be more impressive if it worked, but it seems wrong to mess with art.
PS. Style guides such as no data flow from right to left don't apply to art. Smiley Wink
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 1480 of 2,635
(11,035 Views)
