BreakPoint
Rube Goldberg Code
@altenbach wrote:
Is this supposed to run on an FPGA?
So who can translate it into postage stamp sized code e.g. using boolean arrays instead?
No, it is not for FPGA. Actually author wants to create simple 4-bit shift register with decoder and would like to keep "low-level" logic where one wire according to single bitI was just impressed how accurate all wires placed and arranged on the BD.
As next step probably he will trty to recreate whole Intel 4004 processor as pure Block Diagram:
Smiley Happy
Message 1481 of 2,635
(11,033 Views)
Oh please tell me someone has tried the block diagram clean up?  There is a limit to how big a BD can be it might choke and die on it as it blows up the size attempting to cleanup.
Message 1482 of 2,635
(11,008 Views)
PaulG.
Retired
Message 1483 of 2,635
(10,967 Views)
I just tried the block diagram cleanup in LabVIEW 2011 SP1.
Kudos to whoever coded the block diagram cleanup feature, it completed in about half a second and wasn't too big.
I wouldn't describe the result as beautiful, but you can't expect an algorithm to compete with an artist.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 1484 of 2,635
(10,919 Views)
@PaulG. wrote:
There's only 44 zeros there. It could be worse.
Message 1485 of 2,635
(10,817 Views)
@Hornless.Rhino wrote:
It is worse... I count 46 zeros (if you include the dbl at the init-array and the one on the select), there's probably another one just outside the image region on the other select primative at the far left. Smiley Surprised
Message 1486 of 2,635
(10,814 Views)
Yep I missed 2. Good catch.
Message 1487 of 2,635
(10,738 Views)
Found here.
Not the OP's code, but old Newport example code for motion control. No wonder the poor guy is intimidated by it!
There's a state machine under all that if you dig deep enough.
CLA
Message 1488 of 2,635
(10,592 Views)
I'm not surprised.  In my experience, companies like Newport ask their C programmers do also include a labview driver and examples, even though they have zero experience with labview.  And this is the result...
Message 1489 of 2,635
(10,559 Views)
In comparison, the Aerotech example libraries weren't that bad.
I mean, we still rewrote them as soon as we wanted to use them in anger, but as far as examples go they were reasonable starts.
CLA
Message 1490 of 2,635
(10,556 Views)
