BreakPoint
Rube Goldberg Code
Not really sure if this is a Rube or not - not really sure what this is:
Found this in a driver module for an Elprotronic chip driver "Oscillator.vi".
Kudos to:
1) Whoever managed to write this and deploy it - How did they create a while loop with no wired conditional terminal. This is an infinite loop.
2) NI for such an amazing "feature" in the timed loop!
Can anyone explain why this "works"?
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 1821 of 2,635
(11,453 Views)
You have a "Timed Loop" structure:
According to help
"Unlike the While Loop, the Timed Loop does not require wiring to the stop terminal. If you do not wire anything to the stop terminal, the loop will run interminably."
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 1822 of 2,635
(11,443 Views)
I imagine that somewhere else in that driver you will find something like this:
Yeah, timed loops can be stopped remotely
Message 1823 of 2,635
(11,422 Views)
Holy obfuscation batman!
Josh
Software is never really finished, it's just an acceptable level of broken
Message 1824 of 2,635
(11,410 Views)
They might know about this feature but they also didn't explicitly wire a structure name and kept the default name of "L198724412" so I bet there is a good chance it's just an infinite loop.
Message 1825 of 2,635
(11,409 Views)
Simple question.
In the time it took for me work work out my reply (msg 3) I was beaten by msg 2!
I would like to take loads of credit for ofuconfususication -  or whatever the long word is you keep using!Smiley LOL
http://forums.ni.com/t5/LabVIEW/Access-directly-to-Cluster-on-Front-Panel-inside-other-control/m-p/3...
James
Message 1826 of 2,635
(11,295 Views)
@James_W wrote:
Simple question.
James
Obfuscation
Message 1827 of 2,635
(11,282 Views)
@JÞB wrote:
Obfuscation
yup that's the one Jeff
Obvious-flipping-confusin-ionSmiley Tongue
Message 1828 of 2,635
(11,274 Views)
Or more appropriately. Obfuscation (software), except that many examples of this thread are not deliberate. 😄
Message 1829 of 2,635
(11,259 Views)
We've seen the "Equal TRUE logic" over and over here, so for a change in scenery, let's try a "Not equal FALSE" 😮 There are many ways to write Rube Goldberg code!
(seen here)
Message 1830 of 2,635
(11,186 Views)
