BreakPoint
Rube Goldberg Code
EXT has on Intel 32-bit 80-bits. On Sparc it had 128-bit but that was software emulated. On all other platforms including Intel 64-bit, EXT === DBL.
Rolf Kalbermatter  My Blog
Message 2491 of 2,635
(4,512 Views)
Right.  But on Intel machines, all FP operations are done internally with 80 bits; the extra (guard) bits ensuring that the result will be accurate to the full precision of a 64-bit FP number.  When you use EXT format, you have no guard bits, and (depending on the complexity of the calculation) the accumulated truncation errors can yield a result not much more accurate than a 64-bit FP number.
Message 2492 of 2,635
(4,493 Views)
There is very anecdotal evidence that this is not guaranteed, for example in a thread switch these registers get swapped out as 64bits, and the extra precision is irreversibly lost. (I think it is even more noticeable if you use the parallel FOR loop).
Message 2493 of 2,635
(4,411 Views)
Oh wow!!!!!! (seen here!)
Message 2494 of 2,635
(4,144 Views)
Message 2495 of 2,635
(4,062 Views)
@AeroSoul wrote:
What the...
That is what happens when you give LabVIEW to a C coder with a D average.
Message 2496 of 2,635
(4,034 Views)
Message 2497 of 2,635
(3,950 Views)
Oh wow!
That's just there to make you want to never work on the project - ever! and get the original coder back to redo the code. That's job retention by obfuscation!
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 2498 of 2,635
(3,947 Views)
The 2D array is just a constant after the first value right?
Message 2499 of 2,635
(3,941 Views)
I don't think we can draw any conclusions because even the intent is not clear.
It's not even really a 2D array, just data that would fit equally well into a 1D array caused by the fact that we are autoindexing on the backwards wires creating an array of one element (4, or 3). I am also pretty sure the feedback node was inserted automatically because they created a loop (see also).
Message 2500 of 2,635
(3,914 Views)
