BreakPoint
Rube Goldberg Code
Hmm, I wonder if this could be simplified. (seen here)
Message 2501 of 2,635
(3,964 Views)
@Jacobson-ni wrote:
The 2D array is just a constant after the first value right?
Yes, it'll be [[20],[15]] since the lower loops always gives 1 element out.
Qestit Systems
Certified-LabVIEW-Developer
Message 2502 of 2,635
(3,869 Views)
This
from here.
Also he only posted a picture, not actual code.
Message 2503 of 2,635
(3,743 Views)
Inception fan haha
What are these actually? Never seen these type of data before
Message 2504 of 2,635
(3,729 Views)
@VinnyAstro wrote:
Inception fan haha
That is the old look for a Local Variable.  I'd have to do some digging to figure out when the look changed.  I'm thinking it was in the 2012-2014 time frame.
EDIT:  Wow, the redesign is older than I thought: 2010.
Message 2505 of 2,635
(3,716 Views)
Found that in the other comments.
Still hard working on it apparently haha
Message 2506 of 2,635
(3,702 Views)
@VinnyAstro wrote:
Inception fan haha
As has been mentioned, you have to thank me for that. Similarly, look at the old rectangular boolean constant! 😄
This code is very old, but not prehistoric. For example LabVIEW 4 only had "continue if true" stop conditions but here we have a "stop if true". Stacked sequences were quite popular because the screen resolution was so low (e.g. 640x480, 800x600, 1024x768).
The absolute worst part of stacked sequences were the "sequence locals"., forcing unnatural wire directions.
Message 2507 of 2,635
(3,682 Views)
@VinnyAstro wrote:
Inception fan haha
Heh, i didn't react to that at all. Probably because that was the look when i started using LV and i've used few since they changed the looks. 🙂
Qestit Systems
Message 2508 of 2,635
(3,664 Views)
We can't see any error wires, but i'd assume it's the yellow one and not the older pink ones.
I have a feeling it's LV7 or 8, upgraded from earlier versions.
Qestit Systems
Message 2509 of 2,635
(3,620 Views)
I was always confused how people were putting these on their block diagram !!!
Yes the array example you provide makes a lot of sense actually.
Message 2510 of 2,635
(3,613 Views)
