Certification
CLA requirement tag - #[Covers: ID]
I'm going to have CLA exam in couple weeks. I have a question related with requirement tag - [Covers: ID]. Can I write it in a form of "#[Covers: ID]" (with # character)?  I assume that automated tracking tool will still find those tags, but I would like to be sure 🙂
This way I could track my coverage with bookmarks manager.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 11
(5,446 Views)
There is a dedicated forum board for exam topics, you will get better help there:
https://forums.ni.com/t5/Certification/bd-p/Certification
Message 2 of 11
(5,422 Views)
Should I ask admin for moving my thread?
Michał Bieńkowski
CLA, CTA, CPI
Message 3 of 11
(5,414 Views)
I did it for you 🙂
Message 4 of 11
(5,410 Views)
And I moved the thread.  Anyways...
I am mostly certain that Requirements Gateway will find those tags within longer comments.  If you have RG, go ahead and see if it shows up.
GCentral
Message 5 of 11
(5,372 Views)
How should rqtf file look like to check those tags? Sorry but I've never use this tool 😕
Michał Bieńkowski
CLA, CTA, CPI
Message 6 of 11
(5,345 Views)
Accepted by topic author bienieck
Hi Bienieck,
#[Covers: ID] will work with our RG scripts.
As long as the [Covers: ID] is there it will find everything in comments, VI documentation, etc.
-N
Staff Certification Engineer
Message 7 of 11
(5,343 Views)
Of course if the purpose of this is to track them with the bookmark manager, then you can't have a space in there, or else it will be seen as the end of the tag.  And removing the space may have the tag not seen by NI's automated search.
Message 8 of 11
(5,337 Views)
Hooovahh is correct, you'd have to do some work to tag each requirement #ID[Covers: ID].
Personally I recommend cutting requirements from the text document and pasting them into the VIs and using that as a list of items to still accomplish.
-N
Message 9 of 11
(5,331 Views)
The tag in form of "#[Covers: ID]" will be good to check everything at the end of exam. Bookmarks are sorted so if i will have some typos (eg. [Coevrs: ID]) then I will be able to quickly find it and correct. IDs will still need my visual inspection 🙂 but I will have all of them in bookmarks.
Michał Bieńkowski
CLA, CTA, CPI
Message 10 of 11
(5,326 Views)
