Counter/Timer
Showing results forĀ
Search instead forĀ
Did you mean:Ā
6602 board complementary PWM generation
Hello all;
I want to generate 2 complementary PWM signal in XPC target using NI 6602 board?
Is that possible?
(6,565 Views)
It sure can. Here's a tutorial on the LabVIEW implementation.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(6,544 Views)
Well, thank you Sean but I need to develop my algorithm on MATLAB.
is complementary PWM generation possible by using MATLAB?
(6,531 Views)
Hi gsecer,
You should be able to "translate" the LabVIEW code to the MATLABĀ® script version. I would also consult the MATLABĀ® forums to see if someone else has tried to do this.
Best,
Sean Ferguson
(6,496 Views)
