Counter/Timer
6602 board complementary PWM generation
Hello all;
I want to generate 2 complementary PWM signal in XPC target using NI 6602 board?
Is that possible?
(6,365 Views)
It sure can. Here's a tutorial on the LabVIEW implementation.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(6,344 Views)
Well, thank you Sean but I need to develop my algorithm on MATLAB.
is complementary PWM generation possible by using MATLAB?
(6,331 Views)
Hi gsecer,
This article gives a brief introduction to using the DAQmx driver in MATLAB®. You should be able to "translate" the LabVIEW code to the MATLAB® script version. I would also consult the MATLAB® forums to see if someone else has tried to do this.
Best,
Sean Ferguson
(6,296 Views)
