Counter/Timer
C Pointers and Labview ?
I am using a GT658 TIA board and I would like to have some help running it with LabVIEW.
I can setup the board using the Call Library Function and the board's DLL. My problem is with these 2 functions:
GT65X_add_unpacked_chan(&MeasureObj, 0, TimeData, EventData, ARRAY_SIZE);
GT65X_mrs_obj_read(&MeasureObj, ARRAY_SIZE, 0);
MeasureObj: Structure
TimeData: Array of doubles
EventData: Array of UINT32
ARRAY_SIZE : UINT32 constant.
My problem is that when I do the obj_read, the measured values I want are in the TimeData/EventData array, but the function doesn't return the arrays. So I am guessing that the obj_read function is using a pointer to the TimeData/EventData array to return the data.
How can I access the TimeData/EventData array if the obj_read function doesn't return the array ? Is there a way I can access the wanted array from memory ?
Take care,
Joao Araujo
(6,359 Views)
Hi Joao,
I think this example will give you an idea of how to accomplish the task:
Retrieve Data from a C Array Pointer in LabVIEW
Hope this helps,
Ankita
(6,347 Views)
Hi Ankita, Do you know how to write values from labview to a pointer?
(4,050 Views)
