Counter/Timer
Can you set the inital count in buffered period measurement?
I would like to set the initial count in buffered period measurement, but it seems to always start at zero. Is this a limitation of the hardware?
(3,281 Views)
Greetings,
You can set the initial count of a buffered period measurement, but it will only be applied to the first buffered period. Each subsequent period will begin at zero.
Good luck with your application.
Spencer S.
(3,281 Views)
