Home
Community
Discussion Forums
Most Active Hardware Boards
Counter/Timer
Topic
Counter/Timer
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can you set the inital count in buffered period measurement?
lindab
Member
03-11-2003
07:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I would like to set the initial count in buffered period measurement, but it seems to always start at zero. Is this a limitation of the hardware?
0
Kudos
Message
1
of 2
(3,276 Views)
Reply
Re: Can you set the inital count in buffered period measurement?
Spencer S.
Active Participant
03-13-2003
11:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Greetings,
You can set the initial count of a buffered period measurement, but it will only be applied to the first buffered period. Each subsequent period will begin at zero.
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(3,276 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
