Home
Community
Discussion Forums
Most Active Hardware Boards
Counter/Timer
Topic
Counter/Timer
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Generating a delayed pulse with each AO iteration
cooler
Member
12-15-2001
03:04 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello Filipe:
I attach a Word file,and I describe my problem in it.
Thanks!!"
Generate_a_delayed_pulse_with_AO_boards.doc 25 KB
0
Kudos
Message
1
of 2
(3,600 Views)
Reply
Re: Generating a delayed pulse with each AO iteration
teste
Member
12-17-2001
11:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello;
Thanks for the clarification. What you need is a retriggerable delayed pulse. I'm attaching an example VI which does retriggerable pulse generation. You will need to adapt this code to your needs.
Hope this helps.
Filipe
0
Kudos
Message
2
of 2
(3,600 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
