Counter/Timer
How generate two pulses per cycle? PCI-6251/6255
Hi. I want to generate two or more pulses per cycle like the timming diagram. This pulses will be used to trigger sampling data.
I'm ussing the PCI-6251. The examples VI's for counter outputs can easy generate the first line, but for the second i have no idea. Any information can help.
Another problem could be the synchronization of that lines and the DAQ.
Regards
Ivan C.
(5,230 Views)
Accepted by ivkicin
I would actually use the digital outputs for this--just generate a continuous clock at 1 MHz using  one of the counters and write the following to your digital output lines:
H H H L L L L L L L
H L H L L L L L L L
If you want to use these signals for sampling a different task on the 625x, you would need to wire the output back into one of the PFI lines.
Best Regards,
John Passiak
(5,202 Views)
La mejor forma de crear una señal PWM con la tarjeta 6251 es usar las salidas de contadores . De esta manera puedes ajustar el dity cycle de la onda cuadrada cuando el programa corre.
Te recomiendo visites estas ligas
Pulse Width Modulation (PWM) Using NI-DAQmx and LabVIEW
http://zone.ni.com/devzone/cda/tut/p/id/2991#toc23
Change Counter Output Frequency on the Fly
http://zone.ni.com/devzone/cda/epd/p/id/5493
How Can I Change the Duty Cycle on My Continuous Pulse Train?
http://digital.ni.com/public.nsf/allkb/82C9F3C15F62974E86256EBA0058CAF5?OpenDocument
Si quieres generar la señal empleando tus canales analógicos de salida, este ejemplo te será de utilidad
NI-DAQmx: Creating a Custom Pulse Train Using Analog Output
http://www.ni.com/example/26621/en/
Exito en tu aplicación
(5,166 Views)
