Counter/Timer
How to reset the Terminal Count indicator on the PXI-6608
Dear Community,
Is there any way to reset the terminal count indicator on the PXI-6608? When I Use Get Attribute.vi I get the correct value the first time, but unfortunately (unlike DAQmx) reading the value doesn't reset it...
I'd like to keep track of how many times it has rolled over. And I don't want to use another counter to do that because I'd like to keep them free for other things.
Thanks!
Cas
(3,364 Views)
Accepted by cwierzynski
Traditional daq does not have a means to reset the terminal count indicator, as far as I know. One thing you might be able to do is change the "output mode" to "toggle" and then read the "output state" to determine rollovers by determining when the output state has changed during your application.
I hope this helps!
gus....
(3,361 Views)
