Counter/Timer
How to trigger a Quadrature Encoder with the Z-Signal?
I would like to measure the postion of my engine with a Quadrature Encoder in the X4 mode.
The configuration with the DAQ Assistant is quite easy and it works well with internal and external clock. My only wish - and problem- is that the data reading starts when the Z-Signal occurs. I tried to route the signal on a RTSI channel and take it as a Trigger signal.
I don't know why - but it occurs always an error -200452 which says that there is a problem with a task or a device.
I use the NI-6602 device.
(4,105 Views)
Does the error explanation have any more information than the error code? -200452 means that you are using a property that is not supported by that task. What kind of triggering are you trying to use?
(4,105 Views)
I used the "normal" DAQmx Trigger.vi.
In the meantime I got the recommendation to use the DAQmx Trigger Property Node instead. I didn't try yet - but hopefully it will work.
another thing I did was to install the latest release of NI-DAQ driver. Maybe this makes also a difference.
If you have some other solutions or recommendations - I would be glad to hear about. Thank you.
Andy
(4,105 Views)
Alright, if I understand you correctly, you're trying to measure buffered position, but you want to start the acquisition on the Z-index signal. Position measurement does not support the regular start trigger. Instead you want to use the "Arm Start" trigger from the trigger property node.
Hope this helps!
gus....
(4,105 Views)
Exactly - That's what I am trying now.
It looks good! (till now)
I hope there will be no other surprise.
Thank you for the help.
Andy
(4,105 Views)
