I would like to measure the postion of my engine with a Quadrature Encoder in the X4 mode. The configuration with the DAQ Assistant is quite easy and it works well with internal and external clock. My only wish - and problem- is that the data reading starts when the Z-Signal occurs. I tried to route the signal on a RTSI channel and take it as a Trigger signal. I don't know why - but it occurs always an error -200452 which says that there is a problem with a task or a device.
Does the error explanation have any more information than the error code? -200452 means that you are using a property that is not supported by that task. What kind of triggering are you trying to use?
In the meantime I got the recommendation to use the DAQmx Trigger Property Node instead. I didn't try yet - but hopefully it will work. another thing I did was to install the latest release of NI-DAQ driver. Maybe this makes also a difference. If you have some other solutions or recommendations - I would be glad to hear about. Thank you.
Alright, if I understand you correctly, you're trying to measure buffered position, but you want to start the acquisition on the Z-index signal. Position measurement does not support the regular start trigger. Instead you want to use the "Arm Start" trigger from the trigger property node.
