Counter/Timer
PWM measurement pattern for continuous samples over higher frequencies (100kHz) with SemiPeriod(HighTime / LowTime)
Hi Folks,
I have a challenge which I like to discuss with you and hope to get some ideas and maybe a solution.
I have a National Instruments multifunction data acquisition (DAQ) devices NI-PCIe-6353 this means X-Series!
I'd like to generate and measure Pulse-width modulation  signals.
DRIVER:
OUTPUT:
Freq: 0.1Hz - 1MHz
Duty:    1%  - 99%
change parameter on the fly
(This works fine and is implemented)
INPUT:
Freq: 0.1Hz - 40kHz
Duty:    1%  - 99%
Method of measurement:  Semi-Period / ContinuousSamples / AsyncCallback
Here I have problems I am running only on a Intel(R) Core(TM) 2 Duo CPU E8500 @ 3,16GHz.
And I want to run 2 PWM_IN and 2 PWM_OUT
Low frequency work fine!
0.1Hz - 20kHz
its a Callback loop with
myCounterReader_1.BeginMemoryOptimizedReadMultiSampleDouble(2, myCallback_1, myPWM_IN_1, myPWM_IN_1_Data);
Data = myCounterReader_1.EndMemoryOptimizedReadMultiSampleDouble(ar, out myPWM_IN_1_Data_actualNumberOfSamplesRead);
Higher frequency don't work fine!
20kHz - 40kHz
I get exception Status Code -200279:
Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: NationalInstruments.DAQmx.DaqStream.ReadRelativeToRequested Value:
NationalInstruments.DAQmx.ReadRelativeTo.CurrentReadPosition
Property: NationalInstruments.DAQmx.DaqStream.ReadOffsetRequested Value: 0
Task Name: NI1_PWM_IN_ctr0
Status Code: -200279
40kHz means period = 25us = 12,5us HighTime and 12,5us LowTime by 50% DutyCycle
this means each 25us i get a reading of 2 samples the HighTime and the LowTime
I load my Task from Max so here is the configuration(sorry its german):
1. Can someboby explain me what the MemoryOptimized means?
2. Zu lesende Werte means the buffer size 10 is not a lot but increasing the buffer size to lets say 10.000 want help over
    a longer time!
3. Reading the data more frequently is not possible because the data are live as it is
4. Specifying a fixed number of samples I have der number is 2 HighTime and LowTime
5. I did not start and stop task! Is it better to start and stop the task everytime so that I always have a new buffer perhaps?
Hope someone has an idea for!
By
Steven
(5,165 Views)
Accepted by Sensor-Wiedemann
Software reading with 50 us period - bad idea, you will skip pulses. Try to use DAQmx Read property Overwrite, set it to "overwrite unread samples" - it will overwrite pulses without error.
(5,083 Views)
Hi Alexander,
thanks for your reply I believe this will work!
myPWM_IN_1.Stream.ReadOverwriteMode = NationalInstruments.DAQmx.ReadOverwriteMode.OverwriteUnreadSamples;
Thanks a lot and have a nice day.
God bless you!
(5,069 Views)
