Counter/Timer
PXI 6624: how to set the voltage range
This card support 48VDC, How to select the different voltage when it is configuration as counter or timer.
(1,479 Views)
Accepted by allen9
As per the user manual, the input signal drives a opto-isolator at constant current and hence no regard to input voltage as long as the signal can supply the minimum current 2.2mA.
Santhosh
Soliton Technologies
(1,455 Views)
