Counter/Timer
Pulse Counting Problem CTR-500
I am using a couple CTR-500 on a compact fieldpoint setup to measure pulses from 2 energy (BTU) meters, 3 diaphragm gas meters, 2 liquid flow meters and 2 Watt-hour electrical meters.  I seem to have a problem with my pulse counts accelerating upon start up of the program (up to 1000 pulses/15 minutes <- which is unrealistic for the hardware installed and then falling to 5-10 pulses/15minutes <-reasonable value).  The pulse count does not correlate with the manual meter readings I have taken either, with the exception of the Watthour meters.  I am unsure if it is my program, wiring, or peripheral equipment at this point.
Has anyone seen a problem like this before?  I have included a couple graphs showing the raw pulse count (saved every 15 minutes) and the change in pulse count every 15 minutes.
(7,849 Views)
Hi cmj,
How are you reading the CTR-500?  An example VI may help.
(7,821 Views)
Here is an example vi of how I am reading the pulses and some data processing I am doing with the signal.  I have built in a totalised pulse counter to compensate for the maximum of 65535 pulses that can be counted by the module - so I do not miss pulse counts on reset.
(7,804 Views)
Hi cmj,
Why are you using a FieldPoint Read to get the timestamp?  You should use the Get Date/Time in Seconds VI:
Does this help?  I feel like the code you have right now may not make the case structure work correctly.
(7,777 Views)
I will try out the Get Date/Time in Seconds VI when I get a chance, but the time is only used to save the data (counted pulses) to disk periodically (at 15 minute intervals).  I don't feel this change will help my pulse count problems.  Did you see any problems with the code that is used to actually count the pulses?
(7,736 Views)
Accepted by cmj
Hi cmj,
I need to continue checking your code, but do you have maybe a constant signal you can test the measurements with?  Maybe an extra DAQ card to output a pulse train for testing?
(7,715 Views)
Found a mistake in my code.  I was resetting a number causing a run away.  Thanks for your help.
(7,645 Views)
