Counter/Timer
Pulse train generation issue-PCIe-6320
Hello all..
 Im using PCIe-6320 x series daq to generate pulse train.I have gone through the examples found in the labview to generate digital pulses.Provided vi runs without any error,but i couldnt find any pulse output in my ctr0 pin.Is there any specific connection to be made to check the output?
(6,957 Views)
1. Which pin you're connected to read a pulse and which instrument you use for reading it?
2. Which VI you use and how do you configure it?
(6,858 Views)
Accepted by Sumithra_Nagappan
hi..
 i had an issue with the cable interface ,i found it later.thanks.now i havesolved .
(6,743 Views)
