Counter/Timer
Square waveform generator
I want to make a continuous square waveform. there are some samples and files online to do so, but I'd like to be able to change the frequency of waveform continuously, I mean something like a function generator. I try to use PFI channel in NI 6221, but It just provides waveform with constant frequency. I am wondering if it is a good idea to use PFI channel? I want to provide 100 to kHz square waveform.
(6,057 Views)
Accepted by SardarM
Hi Saridar
This example may be what you are looking for!
Regards
Chris S.
(6,011 Views)
Accepted by SardarM
Hey Chris,
Thanks for your response. It is pretty useful and it gives me some idea for future works.
I got some solution for my case from Labview 8.5 examples. I got theidea that I need to use regeneration mode to make a reliable data, kind of independent of windows interruptpion (I mean, when it is not in regenerate mode, windows updates process or anti-virus process made some lags on the output freq.). I was able to modify the code in a way that it lets me to change the freq. on fly.
Saridar
(6,002 Views)
