Counter/Timer
cpu overloaded problem, 6602 counter board
I am using Matlab XPc target to acquire real time data from 7 encoders.
I am using NI 6602 board
After staring application; within first few seconds, I am getting the error.
"CPU overloaded at time 1-2 seconds"
What could be the reason and solution?
thanks
(4,061 Views)
Hi snoop23,
could you please give a little more information on your setup? Versions of software and drivers that you use would be most helpful.
I'm not sure how relevant this following link may be as I'm not too familiar with Mathworks products, but I think it is worthwhile for you to check it out:
http://zone.ni.com/devzone/cda/tut/p/id/3005
Also, as far as troublshooting goes, do you have any problems if you use only 1 encoder?
Did you install NI Measurement and Automation Explorer (MAX)? Can you acquire data from all channels correctly there?
Kind regards,
(4,047 Views)
