Counter/Timer
divide 20Mhz timebase for counter
Hi everybody,
right now I'm trying to do the following: I use the counter to obtain a rotational angle of an incremental sensor. I need to collect the values with a given sample rate, for example 5kHz. I wanted to use the 20Mhz timebase for that and divide it down, however after 4hours of reading in the knowledge base and the forums, I still haven't gained any ground on how to actually do it.
Anybody already done that and could give an example?
(3,458 Views)
please delete, double post by mistake
(3,455 Views)
